 Ratchet noise from under tank.
rossmofo
rossmofo
Ratchet noise from under tank.  Empty
PostSubject: Ratchet noise from under tank.    Ratchet noise from under tank.  Icon_minitimeFri Jun 14, 2019 10:42 am
Hi, I have recently decided to put the M800 back on the road after a 20 month layoff. In this time it has been started and let warm to running temp etc.
I had charged the battery and checked over the bike for it's MOT when I switched on the ignition to here a ratchet sort of noise from under the tank, thinking it was the fuel pump, I turned it on and off a few times still there.
Took tank off and it turns out it was the secondary butterflies stepper motor making the noise. Butterflies were not wanting to move at all so time to strip it down.
Removed the stepper module and the TP and STP sensors, butterflies still stiff.
Next removed the linkages that go from the secondary butterflies to the throttle stop pivot and there was the problem.
The main pivot has an arm, spring and bronze Bush, the Bush was seized on the pivot pin, some gt85 and gentle persuasion later it was off.
Polished the bore of the bush and coated with moly grease and reassembled everything.
Had to reset the TP and STP sensors.
Bike passed it's MOT and it was great to be on my bike again for the first time in 20months.
goshhub
PostSubject: Re: Ratchet noise from under tank.    Ratchet noise from under tank.  Icon_minitimeFri Jun 14, 2019 11:39 pm
good that u were able to fix it yourself .......nice one.
not been on my bike this year due to moving home , havin to do lots of repairsĀ  and past health issues ,missed it like hell,had to cancel m.o.t. twice .will def get it sorted and ridden v.soon .
have started the bike but will put fresh fuel in tank bfore next fire up ....
all the best Ross . now you got it going, have plenty of rides out like i am hoping to do soon
» Gold near White Cliff's Peak tank NSW??
» Unstable ground signal noise around ant nests
» Rough noise
» front end noise on 2008 RZR
» Cabin noise. Rhino vs RZR
Ratchet noise from under tank.  Icon_minitimeby stingray Mon Feb 17, 2020 8:38 am
» Crash Bars
Ratchet noise from under tank.  Icon_minitimeby Ish992019 Sun Feb 16, 2020 9:26 pm
Ratchet noise from under tank.  Icon_minitimeby pledge Sun Feb 16, 2020 3:29 pm
Ratchet noise from under tank.  Icon_minitimeby RonB58 Fri Feb 14, 2020 5:59 pm
Ratchet noise from under tank.  Icon_minitimeby ardie Fri Feb 14, 2020 11:42 am
» New member in Florida
Ratchet noise from under tank.  Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 6:08 pm
Ratchet noise from under tank.  Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:51 am
» VS1400 rear end on a VS750
Ratchet noise from under tank.  Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:42 am
» Led turn signals!
Ratchet noise from under tank.  Icon_minitimeby mhicks2517 Tue Feb 11, 2020 5:38 pm
Ratchet noise from under tank.  Icon_minitimeby DickB Tue Feb 11, 2020 12:05 pm
Ratchet noise from under tank.  Icon_minitimeby steve co Fri Feb 07, 2020 2:03 pm
Ratchet noise from under tank.  Icon_minitimeby steve co Fri Feb 07, 2020 1:40 pm
Ratchet noise from under tank.  Icon_minitimeby steve co Fri Feb 07, 2020 1:28 pm
» Newby
Ratchet noise from under tank.  Icon_minitimeby malone55 Mon Feb 03, 2020 1:58 pm
» Hello from Stockholm
Ratchet noise from under tank.  Icon_minitimeby stingray Mon Feb 03, 2020 9:49 am
» Glad to be here!
Ratchet noise from under tank.  Icon_minitimeby stingray Mon Feb 03, 2020 9:48 am
» Hey Guys
Ratchet noise from under tank.  Icon_minitimeby oldtom Sun Feb 02, 2020 12:49 pm
» White walls
Ratchet noise from under tank.  Icon_minitimeby ardie Mon Jan 27, 2020 7:52 pm
Ratchet noise from under tank.  Icon_minitimeby creol Sat Jan 25, 2020 8:24 am
» Back in the saddle.
Ratchet noise from under tank.  Icon_minitimeby ardie Fri Jan 24, 2020 8:13 pm
