 The overheat Warning Light is ALWAYS on even when it is 100% cold.
olegsuperman
olegsuperman
The overheat Warning Light is ALWAYS on even when it is 100% cold. Empty
PostSubject: The overheat Warning Light is ALWAYS on even when it is 100% cold.   The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeFri Aug 16, 2019 6:56 pm
Hi there, I have recently got a new bike well atleast it is a new bike to me. long story short i started of with 2014 suzukiburgman then to 2006 yamaha majesty. those were the scooters that i have mastered over few years however now i have got myself a 2006 SUZUKI BULIVARD S50 with only 3700 miles on i love the bike alot!. anyways after u start the bike i get the overheating warning light that is on and it stays on all the time dont metter cold or hot. its just always on. does anyone know anything about this kind of situation ? and what is my steps?
olegsuperman
olegsuperman
PostSubject: Re: The overheat Warning Light is ALWAYS on even when it is 100% cold.   The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeFri Aug 30, 2019 10:43 pm
NOBODY? AM I THE ONLY ONE WITH THIS ISSUE? i have changed the water temp sending unit to the new one that i have got from suzuki dealer and it is the same issue. the radiator switch works fine it turns on and off when it needs to. i have made 5 hr drive on it and it does not overheat its just the light is always on. even when the engine is cool from overnight. i have bought after market water temp gauge hocked it up and on the gauge it tells me that it is overheated what is going on? any one?
johncarter68
johncarter68
PostSubject: Re: The overheat Warning Light is ALWAYS on even when it is 100% cold.   The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeSat Aug 31, 2019 3:14 am
I would check the wiring, maybe a ground wire??
olegsuperman
olegsuperman
PostSubject: Re: The overheat Warning Light is ALWAYS on even when it is 100% cold.   The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeTue Sep 03, 2019 4:08 pm
Honestly I have checked it all. Everything seems to in in order and its place. I even got an aftermarket gauge for water temp. Ones I hocked it up it immediately shows that is at 280C even when it's cold so I ordered a new sensor. I plugged that in and i got the same result. As if it is overheating. I tried to bypass the bikes Ground and did a ground straight from the sensor to the bike or even to the negative wire and it gets the same result. But y? It doesn't make any sence. To b clear I unplugged all the bike wires got a new sensor bypass with all new gauge and it shows that it is overheating. I did this while the sensor is installed on the bike. I will try to do it with the sensor off to c what kind of info I'll get. But still. Y?
» WARNING to DEFAULTERS
» First Light - BBC2, Tuesday the 14th, 9:00pm
» Camner (spelling ?) KY Warning
» Warning label cover.
» xentech hid light kit
Suzuki 800 Intruder Club & Forum :: The Garage :: Cooling system-
» Vz800 handlebars on vs800 ?
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby Ts2028 Yesterday at 9:59 pm
» Hi newby
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby ardie Yesterday at 5:08 pm
» Backrest assembly - part wanted
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby ardie Yesterday at 5:05 pm
» Looking for help with new parts
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby ardie Yesterday at 4:59 pm
» Vl800 regulator
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby lczamorac Yesterday at 6:04 am
» Disable F1 error on O2 sensors ???
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby miffa Sat Mar 28, 2020 7:13 pm
» air flow sensor is doing my head in
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby miffa Sat Mar 28, 2020 11:25 am
» pulling me hair out
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby miffa Sat Mar 28, 2020 11:09 am
» Crash Bars
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby BARNEY Fri Mar 20, 2020 5:25 pm
» Hey all
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby Manamiaman Mon Mar 16, 2020 8:30 pm
» Hey all
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby Manamiaman Sun Mar 15, 2020 1:36 pm
» stingray forum problem
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby ardie Fri Mar 13, 2020 9:59 pm
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby ardie Fri Mar 13, 2020 5:07 pm
» Sachs Roadster 800 porn
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby adilmon Fri Mar 13, 2020 12:19 pm
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby RonB58 Fri Mar 13, 2020 11:08 am
» Healtech XT-S01 X-TRE Fitting instructions
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby creol Fri Feb 28, 2020 12:06 pm
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby Breeze42355 Sun Feb 23, 2020 10:31 pm
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby ardie Sat Feb 22, 2020 6:49 pm
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby pledge Sun Feb 16, 2020 3:29 pm
The overheat Warning Light is ALWAYS on even when it is 100% cold. Icon_minitimeby ardie Fri Feb 14, 2020 11:42 am
