 VL and VZ exhausts interchangeable?
Geordie
VL and VZ exhausts interchangeable? Empty
PostSubject: VL and VZ exhausts interchangeable?   VL and VZ exhausts interchangeable? Icon_minitimeMon Sep 02, 2019 7:12 am
Hi,
I've seen a few exhausts for sale that state both VL andVZ in their fitment, does this mean they are going to fit either model ?
Reason I'm asking is as the owner of a VZ 800 (1999) I have seen an exhaust for sale listed as VL , owner isn't sure if it will fit mine. His is from a 2001 model.
hmac
hmac
PostSubject: Re: VL and VZ exhausts interchangeable?   VL and VZ exhausts interchangeable? Icon_minitimeTue Sep 03, 2019 6:01 pm
Don't think the VL system will fit the VZ. On the VL the exhaust exits from the rear of the rear cylinder head the VZ exits from the front of the rear cylinder head.
Geordie
PostSubject: Re: VL and VZ exhausts interchangeable?   VL and VZ exhausts interchangeable? Icon_minitimeWed Sep 04, 2019 8:50 am
Thanks mate, I didn't bother with them .
How have you fixed the apehangers to yours ?
hmac
hmac
PostSubject: Re: VL and VZ exhausts interchangeable?   VL and VZ exhausts interchangeable? Icon_minitimeThu Sep 05, 2019 12:41 am
To fit apes you will need a pair of risers for 1" bars look for ones that take a 12mm mounting bolt, plenty on ebay etc. The bars I have are an ebay purchase and are from a Harley Street Bob.
There is plenty of slack in the electric cables if you reroute them over the top of the engine and out from behind the steering stem. I had to buy a longer brake line and used universal kits to make longer clutch and throttle cables.  I got the brake line and cable kits from https://www.venhill.co.uk/
If you look close you will see where my electrics for the switch gear is routed. If you need more info just ask.
VL and VZ exhausts interchangeable? 69165989_2107281919376296_4628347467878891520_n.jpg?_nc_cat=102&_nc_oc=AQm4IRbzk4ygjzds1d0vSd9ECMCxUgE3TXwku_DhmvJ2TQiE_bpmSC_1V1VrbGe_k-M&_nc_ht=scontent-lhr3-1
Asmotsat
PostSubject: Re: VL and VZ exhausts interchangeable?   VL and VZ exhausts interchangeable? Icon_minitimeTue Oct 15, 2019 2:45 pm
Ive just tonight bolted up a system (number on mufflers 841f58) which i bought on ebay which i think is from a vl800. on to my boulevard vz800z 2008 (numbers on mufflers 839g28)  muffler diameters were slightly smaller and about an inch shorter in length, but the actual outlet pipe at the back of the muffler was slightly larger. all mountings lined up. o2 sensosor bolted in ok. its too late tonight to fire it up. but tomorrow i will see how it works. i think it looks a bit better as the standard mufflers which in my opinion were a little too fat and a little too long anyway.   I am putting it in for a Roadworthy Test next week,  i hope it passes. it looks very stock standard. only a keen vz expert might spot the difference.  unsure if the sound level will be any different becuase the outlet hole is now slightly larger.
Asmotsat
PostSubject: Re: VL and VZ exhausts interchangeable?   VL and VZ exhausts interchangeable? Icon_minitimeWed Oct 16, 2019 1:26 pm
OK,  it sounds quite nice. slightly deeper rumble. much better than the stock pipes.  my roadworthy test man was not worried about the part number difference, he was happy to see that it had the e4 in a box stamped under the part numbers.    haven't had an opportunity to test its performance or determine any fuel consumption differences yet.
» RCGF 45cc Petrol Engine
» UTV Offroads Exhaust Evaluation for RZR.
» Exhausts for engines....
» Custom dual exhaust on a Twin 16 Briggs & Stratton and some old build pics
» Brand new starter seems to catch on flywheel
VL and VZ exhausts interchangeable? Icon_minitimeby Breeze42355 Sun Feb 23, 2020 10:31 pm
VL and VZ exhausts interchangeable? Icon_minitimeby ardie Sat Feb 22, 2020 6:49 pm
» Crash Bars
VL and VZ exhausts interchangeable? Icon_minitimeby Ish992019 Sun Feb 16, 2020 9:26 pm
VL and VZ exhausts interchangeable? Icon_minitimeby pledge Sun Feb 16, 2020 3:29 pm
VL and VZ exhausts interchangeable? Icon_minitimeby RonB58 Fri Feb 14, 2020 5:59 pm
VL and VZ exhausts interchangeable? Icon_minitimeby ardie Fri Feb 14, 2020 11:42 am
» New member in Florida
VL and VZ exhausts interchangeable? Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 6:08 pm
VL and VZ exhausts interchangeable? Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:51 am
» VS1400 rear end on a VS750
VL and VZ exhausts interchangeable? Icon_minitimeby Lukaszmlynaczyk Thu Feb 13, 2020 11:42 am
» Led turn signals!
VL and VZ exhausts interchangeable? Icon_minitimeby mhicks2517 Tue Feb 11, 2020 5:38 pm
VL and VZ exhausts interchangeable? Icon_minitimeby DickB Tue Feb 11, 2020 12:05 pm
VL and VZ exhausts interchangeable? Icon_minitimeby steve co Fri Feb 07, 2020 2:03 pm
VL and VZ exhausts interchangeable? Icon_minitimeby steve co Fri Feb 07, 2020 1:40 pm
VL and VZ exhausts interchangeable? Icon_minitimeby steve co Fri Feb 07, 2020 1:28 pm
» Newby
VL and VZ exhausts interchangeable? Icon_minitimeby malone55 Mon Feb 03, 2020 1:58 pm
» Hello from Stockholm
VL and VZ exhausts interchangeable? Icon_minitimeby stingray Mon Feb 03, 2020 9:49 am
» Glad to be here!
VL and VZ exhausts interchangeable? Icon_minitimeby stingray Mon Feb 03, 2020 9:48 am
» Hey Guys
VL and VZ exhausts interchangeable? Icon_minitimeby oldtom Sun Feb 02, 2020 12:49 pm
» White walls
VL and VZ exhausts interchangeable? Icon_minitimeby ardie Mon Jan 27, 2020 7:52 pm
VL and VZ exhausts interchangeable? Icon_minitimeby creol Sat Jan 25, 2020 8:24 am
