 4" Rise & Pullback on Suzuki C50T
slej
admin
Farmboy
9 posters
Farmboy
4" Rise & Pullback on Suzuki C50T Empty
PostSubject: 4" Rise & Pullback on Suzuki C50T   4" Rise & Pullback on Suzuki C50T Icon_minitimeTue Apr 19, 2011 1:53 am
Here's the difference the 4" risers make on the 800. These ones happen to be from cruiserworks. I zipped an oem riser on top of the triple tree just to show the difference it makes. It's enough that it takes that little twinge away from between the shoulder blades. I've literally ridden for hours in complete comfort thatnks to this small mod. A highly recommended must-have from this rider. No cable replacements were required.
4" Rise & Pullback on Suzuki C50T ArUS4JBFU8jL0pB5gt1pgOkQ20CNnMHF
PostSubject: Re: 4" Rise & Pullback on Suzuki C50T   4" Rise & Pullback on Suzuki C50T Icon_minitimeTue Apr 19, 2011 10:18 am
How exactly is a riser measured?
Is it from the bottom of the riser to the bottom of the handle bar.
I have often thought about getting some but not sure how the rise is measured
Farmboy
PostSubject: Re: 4" Rise & Pullback on Suzuki C50T   4" Rise & Pullback on Suzuki C50T Icon_minitimeTue Apr 19, 2011 10:56 am
It appears that these are measured that way Intruder. I've got almost 4 & 1/4" from the tree to the bottom of the bar, basically 5" to the bar hole center. That's measured in a straight line. While the added length is the major criteria, the pullback angle I feel is a big player in the comfort factor.
admin
The Final Say!
admin
PostSubject: Re: 4" Rise & Pullback on Suzuki C50T   4" Rise & Pullback on Suzuki C50T Icon_minitimeTue Apr 19, 2011 11:36 am
Cool, thanks for that 4" Rise & Pullback on Suzuki C50T 184121345
slej
slej
PostSubject: Re: 4" Rise & Pullback on Suzuki C50T   4" Rise & Pullback on Suzuki C50T Icon_minitimeFri Mar 29, 2013 1:41 am
the picture seems to be broken...I am very interested.
slej
slej
PostSubject: Re: 4" Rise & Pullback on Suzuki C50T   4" Rise & Pullback on Suzuki C50T Icon_minitimeMon Apr 08, 2013 11:20 pm
No luck on that picture, but the more I read about risers, the more I became convinced I need a set! I ordered these:
4" Rise & Pullback on Suzuki C50T Riser2_zps6283fb58
4" Rise & Pullback on Suzuki C50T Riser1_zps135b184c
They are Baron Custom Accessories Kickback Risers with 4" of rise and 1 1/2" of pull back. I am praying I wont need new cables, and the installation goes smoother that my exhaust 4" Rise & Pullback on Suzuki C50T 4189917092
PostSubject: Re: 4" Rise & Pullback on Suzuki C50T   4" Rise & Pullback on Suzuki C50T Icon_minitimeTue Apr 09, 2013 12:30 am
You should be ok with 4" risers, without changing cables 4" Rise & Pullback on Suzuki C50T 3498837457
PostSubject: Re: 4" Rise & Pullback on Suzuki C50T   4" Rise & Pullback on Suzuki C50T Icon_minitimeTue Apr 09, 2013 10:09 am
Michael if your cables do end up too short,place them at the back of the tree instead of the front,this is what I done when I fitted VL bars to my bike.
PostSubject: Re: 4" Rise & Pullback on Suzuki C50T   4" Rise & Pullback on Suzuki C50T Icon_minitimeTue Apr 09, 2013 9:29 pm
They're nice looking risers by the way 4" Rise & Pullback on Suzuki C50T 3498837457
PostSubject: Re: 4" Rise & Pullback on Suzuki C50T   4" Rise & Pullback on Suzuki C50T Icon_minitimeTue Apr 09, 2013 11:04 pm
2009 is a dodgy year, they could have loads of cable or the may be the shorter ones, it literally depends on the exact point in time of manafacture because 2009 is when they shortened the lengths.
PostSubject: Re: 4" Rise & Pullback on Suzuki C50T   4" Rise & Pullback on Suzuki C50T Icon_minitimeTue Apr 09, 2013 11:39 pm
I had a 4" rise on my 2010 C with stock bars before fitting ape hanger bars and felt the cables were at maximum pull in the stock position. If you have the shorter cables you will probably have to re route behind the triple tree because of the pullback, although you may just get away with it. Let us know how you get on.
slej
slej
PostSubject: Install Complete   4" Rise & Pullback on Suzuki C50T Icon_minitimeFri May 17, 2013 10:59 pm
Thanks y'all for the idea, and the advice. I did have to re route the wires at the signal box on the left, and the throttle cable but...
Finally finished routing the wires and cables....OMG I cannot believe the difference. The best mod I think I will ever do!!!
Ok so for visualaztion's sake here are the factory and baron risers side by side
4" Rise & Pullback on Suzuki C50T 20130504_164740_zps455bb9f0
4" Rise & Pullback on Suzuki C50T 20130504_183206_zps064f4067
Before
4" Rise & Pullback on Suzuki C50T 20130503_105903_zpsc62ba450
4" Rise & Pullback on Suzuki C50T 20130504_161427_zps1fdb2c65
After
4" Rise & Pullback on Suzuki C50T 20130509_180843_zps440071a5
4" Rise & Pullback on Suzuki C50T 20130509_180930_zpsb5b569df
[size=1]
PostSubject: Re: 4" Rise & Pullback on Suzuki C50T   4" Rise & Pullback on Suzuki C50T Icon_minitimeFri May 17, 2013 11:06 pm
They look great! Nice job Michael 4" Rise & Pullback on Suzuki C50T 2170595768
PostSubject: Re: 4" Rise & Pullback on Suzuki C50T   4" Rise & Pullback on Suzuki C50T Icon_minitimeFri May 17, 2013 11:28 pm
Wow what a diffrrence,they look brilliant. 4" Rise & Pullback on Suzuki C50T 2170595768
PostSubject: Re: 4" Rise & Pullback on Suzuki C50T   4" Rise & Pullback on Suzuki C50T Icon_minitimeSat May 18, 2013 6:20 am
They look really good they make a massive difference to the look alone, let alone the riding position 4" Rise & Pullback on Suzuki C50T 123721
Kev Smith
Kev Smith
PostSubject: Re: 4" Rise & Pullback on Suzuki C50T   4" Rise & Pullback on Suzuki C50T Icon_minitimeThu Jul 25, 2013 2:36 pm
I Really like the look of these raisers.....I've added them to my wish list...
Kev
PostSubject: Re: 4" Rise & Pullback on Suzuki C50T   4" Rise & Pullback on Suzuki C50T Icon_minitimeFri Jul 26, 2013 4:59 am
Nice !
» I have just taken delivery of my Suzuki C50T
» my .......... 2011 Suzuki C50T
» Suzuki Boulevard C50T
» My ride a .......... 2006 Suzuki c50t
» Imported from Washington DC .......... Suzuki C50T
4" Rise & Pullback on Suzuki C50T Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
4" Rise & Pullback on Suzuki C50T Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
4" Rise & Pullback on Suzuki C50T Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:52 pm
4" Rise & Pullback on Suzuki C50T Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
4" Rise & Pullback on Suzuki C50T Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
4" Rise & Pullback on Suzuki C50T Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
4" Rise & Pullback on Suzuki C50T Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
4" Rise & Pullback on Suzuki C50T Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
4" Rise & Pullback on Suzuki C50T Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
4" Rise & Pullback on Suzuki C50T Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
4" Rise & Pullback on Suzuki C50T Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
4" Rise & Pullback on Suzuki C50T Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
4" Rise & Pullback on Suzuki C50T Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
4" Rise & Pullback on Suzuki C50T Icon_minitimeby flying1 Wed Jul 31, 2024 1:59 pm
4" Rise & Pullback on Suzuki C50T Icon_minitimeby gary,, Fri Jul 12, 2024 2:30 pm
4" Rise & Pullback on Suzuki C50T Icon_minitimeby gary,, Fri Jul 12, 2024 1:48 pm
4" Rise & Pullback on Suzuki C50T Icon_minitimeby Badger Mon Jul 01, 2024 11:59 am
4" Rise & Pullback on Suzuki C50T Icon_minitimeby wcrawford151 Thu Jun 20, 2024 6:40 pm
4" Rise & Pullback on Suzuki C50T Icon_minitimeby Badger Thu Jun 20, 2024 5:29 pm
4" Rise & Pullback on Suzuki C50T Icon_minitimeby jnsn54398 Tue Jun 18, 2024 5:32 am
