| | My brake light works, but my tail light does not function.. | |
jlink0424 Prospect
 | Subject: My brake light works, but my tail light does not function.. Mon Dec 17, 2012 6:10 am | |
| Hello, My '90 Intruder has some issues in that my tail light is not functioning, however, my brake light works when applying either brake. The bulb has been replaced, I had even taken it to a shop prior, had it fixed and she's having issues again. Is there anything that it could be that I can take care of myself? Thanks, Jason | |
 | Subject: Re: My brake light works, but my tail light does not function.. Mon Dec 17, 2012 9:01 am | |
| Firstly whar did they fix or replace and do you have a voltage meter? | |
 | Subject: Re: My brake light works, but my tail light does not function.. Mon Dec 17, 2012 9:02 am | |
| I believe there are only 3 wires to the combination running/brake light, one earth and two live wires. What did they fix or replace and do you have a voltage meter? It does sound like a corroded connection from what you have said
 | Subject: Re: My brake light works, but my tail light does not function.. Mon Dec 17, 2012 8:48 pm | |
| I would have the rear light apart and clean the connections, do the same with the handlebar light switch and then put a dollop of Vaseline in there and all around the connections. | |
|  | | bigmal Very Valued VIP Member
 | Subject: Re: My brake light works, but my tail light does not function.. Mon Dec 17, 2012 9:05 pm | |
| Dodgy earth? Check for any moisture, signs of cable fraying or poor connections, then as Mr I says, add some vaseline. Hope you get it sorted. | |
 | Subject: Re: My brake light works, but my tail light does not function.. Mon Dec 17, 2012 9:42 pm | |
| The rear Brake/light combo is made up of a single earth and 2 lives so the earth at the bulb is good. However the live may not be good at the bulb but it is a very simple wiring system that is easily followed so if cleaning the connections doesn't work a volt meter is required to see where it is ending. | |
|  | | jlink0424 Prospect
 | Subject: Re: My brake light works, but my tail light does not function.. Tue Dec 18, 2012 3:37 pm | |
| Thanks, I've got the night off so I may try tracing it back. Also, my receipt from the shop says, "wire coming out of ignition switch had came out of the connector, pushing the connector back in and taped the wiring back together." I will take a look around the wiring as well...
 | Subject: Re: My brake light works, but my tail light does not function.. Tue Dec 18, 2012 5:20 pm | |
| Yeah you can bet the issue is in the same place, let us know how you get on. | |
|  | | Sponsored content
 | Subject: Re: My brake light works, but my tail light does not function..  | |
Similar topics |  |
Latest topics | » Hello
by Suzie Thu Aug 11, 2022 1:27 pm
» howdy
by tunnelrat22 Mon Aug 08, 2022 2:16 am
» Marauder Group Brazil greetings everyone!
by schavareto Sun Aug 07, 2022 10:47 pm
» I need electrical help with vz800
by texman51 Sun Aug 07, 2022 9:01 pm
» Hello from new member!
by USATanMan Wed Aug 03, 2022 12:06 am
» Hi from Stevie Mac new member,
by Badger Mon Aug 01, 2022 6:32 pm
» Hey Hey! Jerry here from Phgiladelphia PA
by Badger Mon Aug 01, 2022 6:30 pm
» Problems removing stock exhaust on a C800B 2016
by KeithW Mon Aug 01, 2022 1:57 pm
» Hi Christian here from California
by Chopper13 Mon Aug 01, 2022 4:15 am
» Seat parts needed. Pillon backrest cushion & bracket 1992 VS800
by Stevie Mac Sat Jul 30, 2022 9:31 pm
» Front Brake Squeal
by mog703 Tue Jul 26, 2022 10:03 pm
» Hello from Upstate New York USA
by VL800cRider Fri Jul 22, 2022 8:17 am
» Help! Water pump removal question 1997 VS800
by LNB Tue Jul 19, 2022 7:49 pm
» VL800 stored since 2009. - Need help
by Badger Thu Jul 14, 2022 7:35 pm
» just saying hello to this site
by JohnnyBGood Wed Jul 13, 2022 11:37 pm
by Badger Fri Jul 08, 2022 6:30 pm
» Idiot lights
by Buttsy13 Thu Jun 30, 2022 4:48 pm
» Hello, help with broken Lamda
by Badger Wed Jun 29, 2022 11:11 am
» Nice to be here
by Cannon Sun Jun 26, 2022 10:29 pm
» VX800 Help please, where is the fan connection located.
by rupert Sat Jun 25, 2022 10:10 am
