| Rear brake wear indicator | |
MarcinG Valued VIP Member
| Subject: Rear brake wear indicator Fri Jun 21, 2013 10:22 pm | |
| Gents, Silly questions but I'd rather know than feel sorry later, especially now when I prepare for MOT. 1. Which is the wear indicator... A or B? (and I mean where arrow starts, not where it points) 2. When brake depressed, the lever does not move an awful lot (C)... movement is minimal...is that normal? 3. Should that nut (D) stick out more? I've seen somewhere that it was out more. Overall the brake feels soft, I got about 2,5cm travel on the pedal (which I've read is bang on within the recommended 2 - 3cm range) and it sits rather low - but that might be due to me having footboards instead of pegs. I'm able to lock the rear wheel if I stomp on it proper... not sure the MOT technician will go to these lengths(?) Your feedback is most welcome. | |
| Subject: Re: Rear brake wear indicator Fri Jun 21, 2013 11:33 pm | |
| Hi mate you can download the manual from here LINK Have a look on page 32 and it's all there mate. From you picture the full pad starts nearer to the B and goes past the A when worn Yes that is normal to have very little movement. Nut D looks fine, if you look at the manual you will see the one displayed is actually just past the marker as well. The marker position to the left is where you don't want to get too To check that your rear brake is adjusted properly put your bike on your cruiser lift and tighten the nut on the end of the threaded bar until the rear wheel just starts to grab, then back the nut of a couple of turns and your set If you are unhappy with the position of the pedal adjust it adjust it using the bolt at the pivot point but remember that this can affect the rear brake so check that after you have got the right position. also on page 32 Yes the MOT tester will press that foot pedal down as far as he needs too Hope that helps a little mate | |
| | | Two-Bears * VZ Guru *
| Subject: Re: Rear brake wear indicator Sat Jun 22, 2013 12:49 am | |
| Hello Marcin, I think you will find that the ware marker is line `B` It appears to be well inside the ware limit,,,, Nut `D` is splined rear brake cam and the chromed brake actuating arm is clamped to it with a return spring behind. I agree with captain crash, the MOT tester will press as hard as he needs to when on the brake rollers to get the best reading he can. Changing the standard pegs will most likely mess up the given method of free play check and adjusting as it is based on the given known fixed position of the original peg,,,, that said you can adjust it so it`s comfortable for you to use. Drum brakes i find have a habit of glazing over especially if used too vigorously when new or newly replaced and can make them appear dead or dull when used,,,, when ever you find yourself removing the rear wheel, check the brake shoes, you will probably see that the friction surface of the drum is shiny,,, a fine emery paper rubbed ( i use circular motion ) on the face to dull it and also the surface of the brakes shoes to de-glaze will help it bed them in again, and again as captain crash said adjust so that the brakes don't grab,, press the brake lever several times whilst adjusting to centralize your shoes in the drum, sometimes when you are adjusting brakes you can keep backing off the adjustment because you fell the brake dragging or `tipping` when all it is is the shoes are not central in the drum,,,, it is not such a big problem with this mechanical/ cam actuation type of brake but is good practice. Hope i have been of some help. | |
| Subject: Re: Rear brake wear indicator Sat Jun 22, 2013 7:06 am | |
| So it is the groove on the nut that indicates wear! Glad I asked. Many thanks. | |
| Subject: Re: Rear brake wear indicator Sun Jun 23, 2013 9:58 am | |
| Subject: Re: Rear brake wear indicator | |
