 Question about releasing seated bolts in the Marauder's handlebars
4 posters
AmericanJambo
AmericanJambo
Question about releasing seated bolts in the Marauder's handlebars Empty
PostSubject: Question about releasing seated bolts in the Marauder's handlebars   Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeSun Jun 23, 2013 3:23 pm
Ok, so I'm wanting to add about a 1.5" riser extension to my handlebars but here's the tricky part. The Marauder's handlebars have seated bolts that aren't long enough to accommodate more than about a .75" extension. Does anyone know of an easy way to remove the seated bolts from the handlebars? Thanks guys!
PostSubject: Re: Question about releasing seated bolts in the Marauder's handlebars   Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeSun Jun 23, 2013 4:43 pm
By "seated bolts" do you mean threaded bar that's .75" longer than actually needed to go through the triple tree? If so, They'll be threadlocked in probably, I'd spin a nut up the bar an inch or so, and then put a lock nut on right behind it and tighten the nut up to the lock nut, that should release the threaded bar from the riser part of your bars as you tighten it up.
AmericanJambo
AmericanJambo
PostSubject: Re: Question about releasing seated bolts in the Marauder's handlebars   Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeSun Jun 23, 2013 11:41 pm
Yep. That's exactly the info I'm looking for. Thanks brother!
Rob Reimer
Rob Reimer
PostSubject: Re: Question about releasing seated bolts in the Marauder's handlebars   Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeFri Jan 10, 2014 3:40 am
Did you ever get the studs out of your bars? I would like to do this also, but do not know if the studs will come out.
Two-Bears
* VZ Guru *
Two-Bears
PostSubject: Re: Question about releasing seated bolts in the Marauder's handlebars   Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeFri Jan 10, 2014 6:29 am
Hello Rob,
I don't know of anyone getting the bolts out,,, If I recall they are a shoulder bolt welded into the end of the bars,, I suppose if you really wanted to you could cut them off and re-engineer them,, the handle bars are I believe called T-BARS by design and there is only 3/4 inch of thread left to raise the bars, a popular remedy for this is to fit Yamaha fat T-BARs, they are a bit wider, a bit higher,, come back to you a littleĀ and the if I recall correctly you only have to move the cables from in front of the yolk/triple tree to the rear.
Hope this is of some help to you.
» Rear Sprocket Bolts
» What length exhaust bolts ?
» Changing from chrome to coloured anodised bolts?
» 6mm cylinder / head bolts that also hold chrome cover
» 2nd air question vz800
» Very new, new member
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby Badger Tue Jan 21, 2025 7:32 pm
» Hydraulic clutch pushrod.
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby Badger Fri Jan 17, 2025 4:23 pm
» Hello from Germany
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby Badger Thu Jan 16, 2025 12:20 am
» Oops I killed it,, I think?
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby Badger Tue Jan 14, 2025 11:24 am
» Greetings from up North
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby noahgtb Wed Jan 08, 2025 9:55 pm
» Old FNG
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby Badger Sun Dec 29, 2024 3:37 pm
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby Anarchy2007 Tue Dec 10, 2024 9:47 pm
» Hello everyone
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby GL600 Mart Thu Dec 05, 2024 12:10 pm
» Hi, I'm Mia
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby M14OVP Wed Dec 04, 2024 8:56 pm
» Electronic fuel injection
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby 03580 Wed Dec 04, 2024 12:32 pm
» Clutch Replacement
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby Badger Tue Nov 26, 2024 11:38 am
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby Badger Tue Nov 26, 2024 11:33 am
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Question about releasing seated bolts in the Marauder's handlebars Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
