 VL 800 Rear wheel removal
Jimmyboy
8 posters
VL 800 Rear wheel removal  Empty
PostSubject: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeMon Aug 26, 2013 5:50 pm
Hiya
Now I've been pointed in the right direction for tyres (thank you Captain Crash), I need to get the rear wheel out of my '01 Volusia.  Piece of cake on the Katana, mudguard was under the seat.  Not so sure about this - that huge rear fender almost sits on the ground.  I've looked at the video clip of the home made wood jack/lift, but I'm not sure if it will lift the wheel high enough.  Is it easier to do by removing the fender?
I'm moderately competent/confident to try & tackle it - is it do-able, or would it be easier to ride down the dealers?  I just don't want to pay a fortune for something that looks like it should be easy.
Any tips/advice welcome
Thanks
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeMon Aug 26, 2013 10:07 pm
I'd have thought it's do-able with a home made lift, might be tight and you'd have to have the wheel out at an angle, to get it out from under the fender, It would be easier to take it to the dealers and pay, but why not buy a proper bike lift with the money you'd pay the dealer? then you've got one for any future jobs.
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeMon Aug 26, 2013 11:08 pm
I can recommend Liftmaster.... Proper solid lift. I did a unboxing/review on my youtube channel a while ago if you want a look before buy.
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeMon Aug 26, 2013 11:39 pm
Good idea, I didn't realise they were that cheap nowadays.
Marcin, can I ask if yours is the 14" or 17" lift version?
Cheers, Dave
Jimmyboy
Jimmyboy
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeSat Dec 21, 2013 9:33 am
Get a lift mate, check second hand as I picked one up for £35 quid (if I remember right), the thing is some people will buy these lifts to do a job and then never use them again and then end up selling them, this was the case with the one I got as it was like new.
Jim.
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeSat Dec 21, 2013 10:59 am
Cheers, Dave
Mine is the wider one if I remember right.
Just checked, yes, it's the 17" wide base. And to be honest, I don't think I'd be happy with 14", seeing how much spece I got left on both sides.
Jimmyboy
Jimmyboy
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeSat Dec 21, 2013 1:36 pm
Mine is the narrower one but when its on its solid but wider would be better.
Jim.
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeSat Dec 21, 2013 1:52 pm
Mine just fits under the frame with an inch or two either side, not brilliant but I only use it for getting the rear wheel off.
For everything else, when doing usual maintenance & cleaning I use the Home made jack, that's no good for removing the rear wheel though.
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeSat Dec 21, 2013 2:15 pm
Do you not have an issue with weight on those cruiser lifts if you take the rear wheel off. What I mean is would it possibly fall forward cause there was suddenly no weight at the back?
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeSat Dec 21, 2013 2:37 pm
Happily texting from the road...good day for a ride. :)
Not really Crash. I sat on mine while it was at maximum height and wobbled it back and forth. Rock solid. Most weight is a engine  so as long as you set the lift in a way that front wheel goes up first when rising, you should have no problems.
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeSat Dec 21, 2013 6:06 pm
If any doubt is there it would always be possible to secure the bike frame to the lift.
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeSat Dec 21, 2013 6:07 pm
Absolutely...and the lift I got comes with straps to secure it.
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeSat Dec 21, 2013 6:24 pm
Good to know that for the peace of mind
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeSat Dec 21, 2013 9:03 pm
Liftmaster, with the larger platform, about £100 - nothing within a reasonable distance on ebay so looks like that's the one to go for
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeSat Dec 21, 2013 11:08 pm
VL 800 Rear wheel removal  Image_23588
my daughter is giving me money to buy this one for Christmas. I hope it will work on my trike
Bigredbus4468
Bigredbus4468
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeSun Dec 22, 2013 10:48 am
I have one of these from my previous cruisers luckily. Works brilliantly and takes 450KG.
http://www.demon-tweeks.co.uk/motorcycle/bike-lifts-movers/motrax-mini-jack
VL 800 Rear wheel removal  Trans
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeSun Dec 22, 2013 10:50 am
How's the balance on one like that Kevin?
Bigredbus4468
Bigredbus4468
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeSun Dec 22, 2013 10:54 am
Not tried it on my M800 yet. I take of the little arms on top, place a bit of deckboard on the flat platform and then lift on the frame. Seemed stable on the HDs but the M800 frame is better and there is more room to work and the frame is the lowest point all the way across the frame.
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeSun Dec 22, 2013 2:00 pm
Was looking at this  at the bike show in November.  Fantastic piece of kit & they will make an adapter to fit almost any bike.  Can't justify spending over £350 on it though - it just wouldn't get the use.  Still think it's going to be the Liftmaster - seems to have constantly good reviews on Amazon (yes, I've seen Marcins)
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeSun Dec 22, 2013 5:25 pm
Ace lifts but the price is in another league for me. Very handy tho and easy to use anywhere
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeSun Dec 22, 2013 5:26 pm
Ace lifts but the price is in another league for me. Very handy tho and easy to use anywhere and they do them with a vl800 fitting as well
Bigredbus4468
Bigredbus4468
PostSubject: Re: VL 800 Rear wheel removal    VL 800 Rear wheel removal  Icon_minitimeMon Dec 23, 2013 8:27 am
Just wacked it on the lift. Works great. Bike too low to use the arms but it is very stable. No problem lifting the front or rear of the cycle.
» rzr rear wheel bearing
» Rear Wheel Bearing Cross Ref.
» Rear Wheel Steer.
» How do you remove stuck rear wheel hubs?
» murray widebody steering wheel removal.
VL 800 Rear wheel removal  Icon_minitimeby Badger Fri Jan 21, 2022 10:09 am
» low power in electrics. - Causes?
VL 800 Rear wheel removal  Icon_minitimeby Damion Jones Thu Jan 20, 2022 9:46 pm
» Hi Gals & Guys from Pete
VL 800 Rear wheel removal  Icon_minitimeby Badger Fri Jan 14, 2022 7:20 pm
» New indicators
VL 800 Rear wheel removal  Icon_minitimeby Paulw66 Sun Jan 09, 2022 8:29 pm
» VS1400 rear end on a VS750
VL 800 Rear wheel removal  Icon_minitimeby Lukaszmlynaczyk Sun Jan 09, 2022 10:02 am
» Lock the steering - VZ800
VL 800 Rear wheel removal  Icon_minitimeby ssalvado Fri Jan 07, 2022 6:42 pm
» Bike not starting
VL 800 Rear wheel removal  Icon_minitimeby compromarly@gmail.com Fri Jan 07, 2022 12:26 pm
» Filling in baffle holes
VL 800 Rear wheel removal  Icon_minitimeby Uneasy_Rider Thu Jan 06, 2022 12:52 am
» Has anyone installed a rear swingarm, from suzuki vs 1400 to vs 800?
VL 800 Rear wheel removal  Icon_minitimeby Jek Tue Jan 04, 2022 6:13 pm
» Hello from belarus
VL 800 Rear wheel removal  Icon_minitimeby Jek Tue Jan 04, 2022 2:44 pm
» Hello from NC USA
VL 800 Rear wheel removal  Icon_minitimeby pasleyspabulum Fri Dec 31, 2021 5:37 pm
» VX reg/rec location
VL 800 Rear wheel removal  Icon_minitimeby Damion Jones Wed Dec 29, 2021 8:16 pm
» Rebaffle?
VL 800 Rear wheel removal  Icon_minitimeby pasleyspabulum Mon Dec 27, 2021 12:35 pm
» Lambda sensors - HELP!
VL 800 Rear wheel removal  Icon_minitimeby Badger Mon Dec 20, 2021 7:38 pm
» Vz800 head port and polishing
VL 800 Rear wheel removal  Icon_minitimeby Dfreel43 Sat Dec 18, 2021 6:08 pm
» Another newbie from Somerset
VL 800 Rear wheel removal  Icon_minitimeby John4393 Fri Dec 17, 2021 10:20 pm
» ORIGINAL INTRUDER OWNER'S T-SHIRTS FOR ONLY $18.00 NOW!
VL 800 Rear wheel removal  Icon_minitimeby katsd Thu Dec 16, 2021 2:23 pm
» Bike Lifts
VL 800 Rear wheel removal  Icon_minitimeby Dermagraphic Wed Dec 15, 2021 12:45 pm
» Hello from Plymouth
VL 800 Rear wheel removal  Icon_minitimeby jessausten Mon Dec 13, 2021 1:33 pm
» New Member - VX800 owner from Miami
VL 800 Rear wheel removal  Icon_minitimeby Maroon VX800 Sun Dec 12, 2021 8:19 pm
