 Rear brake seized!
7 posters
Rear brake seized! Empty
PostSubject: Rear brake seized!   Rear brake seized! Icon_minitimeMon Mar 24, 2014 10:53 pm
I've been out on the Triumph for the last 2 maybe 3 weeks and the Intruders been sat in the garage. It was working perfectly when I parked it up. But when I went to get it out on Saturday I noticed the rear brake pedal is completely locked up. Cant move it up or down. The pedal seems to be locked in the 'up' position as the brake is not being applied. Any ideas folks?
PostSubject: Re: Rear brake seized!   Rear brake seized! Icon_minitimeMon Mar 24, 2014 11:12 pm
Perhaps it's just the lever?
You do ride it hard and dirty so maybe the lever itself needs some love?
PostSubject: Re: Rear brake seized!   Rear brake seized! Icon_minitimeMon Mar 24, 2014 11:53 pm
I agree with Marcin, clean the bike and add lube. You can't expect a bike to love you in return for not loving it
PostSubject: Re: Rear brake seized!   Rear brake seized! Icon_minitimeTue Mar 25, 2014 7:44 am
Since my last telling off I try and keep the bike fairly clean nowadays. I too thought the lever mechanism might be fouled so again I soaked it with acf50 and scrubbed it all out but still the same problem.
PostSubject: Re: Rear brake seized!   Rear brake seized! Icon_minitimeTue Mar 25, 2014 9:56 am
It's strange that it would sieze up in disengaged position.
Anything in between the lever and the drum that might have been bent perhaps?
Just trying to rule out everything outside of drum.
PostSubject: Re: Rear brake seized!   Rear brake seized! Icon_minitimeTue Mar 25, 2014 2:37 pm
Hmm not sure mate, I'll have a closer look but its only been sitting in the garage. I think i'll see if I can disconnect the foot pedal from the rod/cable that connects to the drum, so I can see which part is not moving then
PostSubject: Re: Rear brake seized!   Rear brake seized! Icon_minitimeTue Mar 25, 2014 4:04 pm
Joe it would be easier to disconnect the road it at the rear spring in the first place rather than at the pedal just to ses if it a brake or connection issue
PostSubject: Re: Rear brake seized!   Rear brake seized! Icon_minitimeTue Mar 25, 2014 4:51 pm
Hi Joe I think CC is still smoking weed,disconnect at the rear of rod,and see if your pedal moves then,if not check the middle of your frame under the exhaust,there is a spring in the linkage there,make sure that is intact and not causing anything to jam,apart from a bent rod Joe there is not a lot it can be.(CC only joking over the weed,just laughing at your avatar,and spelling.)
PostSubject: Re: Rear brake seized!   Rear brake seized! Icon_minitimeTue Mar 25, 2014 5:17 pm
Just push the lever forward against the spring on the drum, If it moves? it's the pedal that's seized, if not? It'll be the flat part of the brake shoes that have rusted to the pivot inside the drum, more likely to be the latter of the two.
PostSubject: Re: Rear brake seized!   Rear brake seized! Icon_minitimeTue Mar 25, 2014 6:00 pm
Joe as Sim says only if you have time/space drop the wheel out anyway & have a look at the actuating lever etc.
Has the pedal been pulled back for some reason as if so it may have pushed the mechanism over centre & it may be jammed up.
Just a thought ok, Oh & use some copper grease on any pivots if you can dismantle them but be very careful at the drum pivot & do not use too much as it may get on the brake shoes!
PostSubject: Re: Rear brake seized!   Rear brake seized! Icon_minitimeWed Mar 26, 2014 9:24 am
Can't say I am surprised, even though this is something I would never of predicted. Done an oil change yet?
Just lube all the pivot point's well & go back a few day later to try sorting it out, it will be easier that way & good for the bike.
PostSubject: Re: Rear brake seized!   Rear brake seized! Icon_minitimeWed Mar 26, 2014 12:52 pm
Bike was last serviced in January, and is clean and oiled. Makes me think its something in the drum, but theres no point guessing whilst I have the means to test it once I have some spare time. Thanks for all your advice chaps, will let you know
PostSubject: Re: Rear brake seized!   Rear brake seized! Icon_minitimeWed Mar 26, 2014 4:50 pm
Whatever it is Joe,it should not be too much,good luck with it.
PostSubject: Re: Rear brake seized!   Rear brake seized! Icon_minitimeWed Mar 26, 2014 8:17 pm
Agreed should be simples
Rear brake seized!
» Rhino Rear Brake?????
» Rhino Rear Brake AWFUL Noise -- Normal??
» Rear Brake Rotor
» Rhino Brake Problem?
» Need help with brakes
» Petcock gasket VX800 M
Rear brake seized! Icon_minitimeby VX800-PCW Thu Jan 27, 2022 4:08 pm
Rear brake seized! Icon_minitimeby Badger Fri Jan 21, 2022 10:09 am
» low power in electrics. - Causes?
Rear brake seized! Icon_minitimeby Damion Jones Thu Jan 20, 2022 9:46 pm
» Hi Gals & Guys from Pete
Rear brake seized! Icon_minitimeby Badger Fri Jan 14, 2022 7:20 pm
» New indicators
Rear brake seized! Icon_minitimeby Paulw66 Sun Jan 09, 2022 8:29 pm
» VS1400 rear end on a VS750
Rear brake seized! Icon_minitimeby Lukaszmlynaczyk Sun Jan 09, 2022 10:02 am
» Lock the steering - VZ800
Rear brake seized! Icon_minitimeby ssalvado Fri Jan 07, 2022 6:42 pm
» Bike not starting
Rear brake seized! Icon_minitimeby compromarly@gmail.com Fri Jan 07, 2022 12:26 pm
» Filling in baffle holes
Rear brake seized! Icon_minitimeby Uneasy_Rider Thu Jan 06, 2022 12:52 am
» Has anyone installed a rear swingarm, from suzuki vs 1400 to vs 800?
Rear brake seized! Icon_minitimeby Jek Tue Jan 04, 2022 6:13 pm
» Hello from belarus
Rear brake seized! Icon_minitimeby Jek Tue Jan 04, 2022 2:44 pm
» Hello from NC USA
Rear brake seized! Icon_minitimeby pasleyspabulum Fri Dec 31, 2021 5:37 pm
» VX reg/rec location
Rear brake seized! Icon_minitimeby Damion Jones Wed Dec 29, 2021 8:16 pm
» Rebaffle?
Rear brake seized! Icon_minitimeby pasleyspabulum Mon Dec 27, 2021 12:35 pm
» Lambda sensors - HELP!
Rear brake seized! Icon_minitimeby Badger Mon Dec 20, 2021 7:38 pm
» Vz800 head port and polishing
Rear brake seized! Icon_minitimeby Dfreel43 Sat Dec 18, 2021 6:08 pm
» Another newbie from Somerset
Rear brake seized! Icon_minitimeby John4393 Fri Dec 17, 2021 10:20 pm
» ORIGINAL INTRUDER OWNER'S T-SHIRTS FOR ONLY $18.00 NOW!
Rear brake seized! Icon_minitimeby katsd Thu Dec 16, 2021 2:23 pm
» Bike Lifts
Rear brake seized! Icon_minitimeby Dermagraphic Wed Dec 15, 2021 12:45 pm
» Hello from Plymouth
Rear brake seized! Icon_minitimeby jessausten Mon Dec 13, 2021 1:33 pm
