 hazard lights on 2003 volusia
4 posters
strontyd
strontyd
hazard lights on 2003 volusia Empty
PostSubject: hazard lights on 2003 volusia   hazard lights on 2003 volusia Icon_minitimeSun Apr 20, 2014 10:42 pm
my 2003 volusia has a hazard light switch which only seems to illuminate the right hand indicators front and back, i know its not a MOT requirement but would be nice to get it working. anyone know the correct function of the hazards and if it is just something like a flasher unit faulty? if so where is it located?
cheers
PostSubject: Re: hazard lights on 2003 volusia   hazard lights on 2003 volusia Icon_minitimeMon Apr 21, 2014 8:02 am
That's a new one on me, hazard switch pressed and only the right indicators being activated if all else is OK with the indicator use. Remove the chrome secondary gear case cover on the lower left side of the bike, it's under there. It is a dual purpose relay as it also works the side stand as well cut off as well.
strontyd
strontyd
PostSubject: Re: hazard lights on 2003 volusia   hazard lights on 2003 volusia Icon_minitimeWed Apr 23, 2014 1:14 am
Thanks I will investigate further. All other functions of indicators are fine. I have a manual so will trawl through the schematics.
PostSubject: Re: hazard lights on 2003 volusia   hazard lights on 2003 volusia Icon_minitimeWed Apr 23, 2014 5:05 pm
Gotta be the relay surely, cant think of another scenario that could make that happen if the indicators are all fine?
CanadianCruiser
CanadianCruiser
PostSubject: Re: hazard lights on 2003 volusia   hazard lights on 2003 volusia Icon_minitimeSat Apr 25, 2015 1:49 pm
Might be some corrosion in the switch or a short in the line... Typically if your flashers are functioning normally then the relay will be fine and issue is with switch or connections..
Hazzards use the existing flasher wiring with one exception... there will be wires that taps into and runs from each the left side and right side lighting (+) to your switch then one that taps into and runs from the (-) side of the relay...
the three of them route into your switch, when you press the button it connects all 3 completing the circuit.
My money's on corrosion in the switch..
» .....Hazard Warning Lights, New Idea!.....
» Volusia 2003 Air filter cleaning
» Picture of my .......... 2003 Suzuki Intruder Volusia
» Modified rear fender ...... 2003 Suzuki Volusia
» Just installed 8" risers...enjoy! .... 2003 Suzuki Volusia Ltd Edition
hazard lights on 2003 volusia Icon_minitimeby beachartist Yesterday at 1:10 am
hazard lights on 2003 volusia Icon_minitimeby ian7be Mon Sep 18, 2023 7:47 am
hazard lights on 2003 volusia Icon_minitimeby Reggyreg Sat Sep 16, 2023 8:41 pm
hazard lights on 2003 volusia Icon_minitimeby webrider Thu Sep 14, 2023 1:34 pm
hazard lights on 2003 volusia Icon_minitimeby Nat Mon Sep 11, 2023 9:56 pm
hazard lights on 2003 volusia Icon_minitimeby greatwave Thu Sep 07, 2023 1:38 am
hazard lights on 2003 volusia Icon_minitimeby Groovy Dinner Wed Sep 06, 2023 6:44 pm
hazard lights on 2003 volusia Icon_minitimeby Badger Mon Sep 04, 2023 11:42 am
hazard lights on 2003 volusia Icon_minitimeby Badger Thu Aug 24, 2023 11:08 am
hazard lights on 2003 volusia Icon_minitimeby flying1 Thu Aug 24, 2023 10:38 am
hazard lights on 2003 volusia Icon_minitimeby Fergal Tue Aug 08, 2023 6:18 pm
hazard lights on 2003 volusia Icon_minitimeby Fergal Tue Aug 08, 2023 6:09 pm
hazard lights on 2003 volusia Icon_minitimeby Badger Wed Jul 26, 2023 10:31 am
hazard lights on 2003 volusia Icon_minitimeby Badger Mon Jul 17, 2023 9:05 am
hazard lights on 2003 volusia Icon_minitimeby Fargo02 Mon Jul 17, 2023 1:28 am
hazard lights on 2003 volusia Icon_minitimeby Slickrickk Mon Jul 17, 2023 12:36 am
hazard lights on 2003 volusia Icon_minitimeby Damion Jones Sun Jul 16, 2023 11:22 pm
hazard lights on 2003 volusia Icon_minitimeby BEEMERED Sun Jul 16, 2023 1:41 pm
hazard lights on 2003 volusia Icon_minitimeby uskydoo Sun Jul 16, 2023 10:45 am
hazard lights on 2003 volusia Icon_minitimeby Ray944 Sun Jul 09, 2023 5:41 am
