 my first go at my poor headlight
4 posters
johnnyfaulty
johnnyfaulty
my first go at my poor headlight  Empty
PostSubject: my first go at my poor headlight    my first go at my poor headlight  Icon_minitimeSun May 29, 2016 11:45 pm
well guys  and gals as this is my first road bike i thought i would have a crack at some jobs that i need to do on my marauder ..
first thing was to wire up the 2 small spot lights that were on me bike when i bought it . ( some numpty had not put a relay on ) so new 25w bulbs new relay and presto job done ..
the next job is to sort out my head light , it is nothing short of dangerous to ride with at night ..
it seems that full beam does nothing other than dim the light . dip beam is bright prob as it should be , but full beam is near nothing there , i have tried tweeking the light angle  up and down ,seems to make no difference ,  the only way i can ride after dark is if i hold the flash /pass button , this is very bright again prob as full beam should be  .
is there anything i need to look at before i give in and buy a bandit headlight and make it fit ..
thanks for any help
in advance
ross
PostSubject: Re: my first go at my poor headlight    my first go at my poor headlight  Icon_minitimeMon May 30, 2016 12:05 am
Bad earth or its wired up wrong!!
PostSubject: Re: my first go at my poor headlight    my first go at my poor headlight  Icon_minitimeMon May 30, 2016 8:26 am
Agreed Andrew! Take it apart & clean the terminals etc & start from there also you may want to take the handlebar switch off & give it some spray with WD40 or similar as it may also be a bad contact in the switch itself!
PostSubject: Re: my first go at my poor headlight    my first go at my poor headlight  Icon_minitimeMon May 30, 2016 12:13 pm
Mine was the same after I refitted the headlight - took it out, cleaned the contacts & made sure the connector was pushed fully home
johnnyfaulty
johnnyfaulty
PostSubject: Re: my first go at my poor headlight    my first go at my poor headlight  Icon_minitimeMon May 30, 2016 3:16 pm
cheers guys ..
i have prob had the light out 10 times checking and cleaning  .  so i think it maybe good there .. is there a relay for  dim/high beam ? where would be the earth points on this machine ,
cheers again peeps ..
ross
PostSubject: Re: my first go at my poor headlight    my first go at my poor headlight  Icon_minitimeMon May 30, 2016 5:06 pm
So it's working if you use the pass button - when you say it's very dim on the main beam switch, do you mean it's actually coming on, but not very bright ?  From what you're saying, it sounds like it's going to be a switch issue - if it's coming on fine on the pass button, I'd guess that the contact is at fault.  In the first instance, I'd strip the switch down (make sure you take plenty of photos - believe me, you'll never remember where it all goes), see if the wiring looks OK & make sure the contacts are clean.
Failing that, you're probably going to be trawling ebay for a replacement switch, I'm afraid
PostSubject: Re: my first go at my poor headlight    my first go at my poor headlight  Icon_minitimeTue May 31, 2016 5:28 pm
As I said Dave, try the switch clean!
PostSubject: Re: my first go at my poor headlight    my first go at my poor headlight  Icon_minitimeTue May 31, 2016 6:37 pm
Sorry Pete, missed that. !
johnnyfaulty
johnnyfaulty
PostSubject: Re: my first go at my poor headlight    my first go at my poor headlight  Icon_minitimeTue May 31, 2016 11:36 pm
ok guys , i will take the switch out and give a good clean , yes katsd it works it's just dull as fook ..
will report back after i clean the switch out
thanks
ross
PostSubject: Re: my first go at my poor headlight    my first go at my poor headlight  Icon_minitimeWed Jun 01, 2016 4:29 pm
No probs mate you're probably on lates so that's screwing your eyesight up lol!
PostSubject: Re: my first go at my poor headlight    my first go at my poor headlight  Icon_minitimeWed Jun 01, 2016 4:32 pm
Spot-on mate - just finished three of the busiest late shifts I've done in ages.
Re Johnny's issue - I'm guessing there's going be crap in the switch meaning it won't be making a good contact
PostSubject: Re: my first go at my poor headlight    my first go at my poor headlight  Icon_minitimeWed Jun 01, 2016 4:36 pm
Yeh that's what I thought Dave as if it's ok on the pass switch then it must be a bar switch problem. Welcome back to normality mate ha ha ha........
» Poor starting
» Vx800 poor compression
» Clutch and poor running query
my first go at my poor headlight  Icon_minitimeby KeithW Mon Oct 02, 2023 5:13 pm
my first go at my poor headlight  Icon_minitimeby beachartist Sun Sep 24, 2023 1:10 am
my first go at my poor headlight  Icon_minitimeby ian7be Mon Sep 18, 2023 7:47 am
my first go at my poor headlight  Icon_minitimeby Reggyreg Sat Sep 16, 2023 8:41 pm
my first go at my poor headlight  Icon_minitimeby webrider Thu Sep 14, 2023 1:34 pm
my first go at my poor headlight  Icon_minitimeby Nat Mon Sep 11, 2023 9:56 pm
my first go at my poor headlight  Icon_minitimeby greatwave Thu Sep 07, 2023 1:38 am
my first go at my poor headlight  Icon_minitimeby Groovy Dinner Wed Sep 06, 2023 6:44 pm
my first go at my poor headlight  Icon_minitimeby Badger Mon Sep 04, 2023 11:42 am
my first go at my poor headlight  Icon_minitimeby Badger Thu Aug 24, 2023 11:08 am
my first go at my poor headlight  Icon_minitimeby flying1 Thu Aug 24, 2023 10:38 am
my first go at my poor headlight  Icon_minitimeby Fergal Tue Aug 08, 2023 6:18 pm
my first go at my poor headlight  Icon_minitimeby Fergal Tue Aug 08, 2023 6:09 pm
my first go at my poor headlight  Icon_minitimeby Badger Wed Jul 26, 2023 10:31 am
my first go at my poor headlight  Icon_minitimeby Badger Mon Jul 17, 2023 9:05 am
my first go at my poor headlight  Icon_minitimeby Fargo02 Mon Jul 17, 2023 1:28 am
my first go at my poor headlight  Icon_minitimeby Slickrickk Mon Jul 17, 2023 12:36 am
my first go at my poor headlight  Icon_minitimeby Damion Jones Sun Jul 16, 2023 11:22 pm
my first go at my poor headlight  Icon_minitimeby BEEMERED Sun Jul 16, 2023 1:41 pm
my first go at my poor headlight  Icon_minitimeby uskydoo Sun Jul 16, 2023 10:45 am
