| | * HardKrome Quite Baffles For V&H Cruzers C800 * | |
 | Subject: * HardKrome Quite Baffles For V&H Cruzers C800 * Sat Oct 08, 2011 3:26 pm | |
| I installed my HardKrome Quiet Baffles in to my Vance and Hines Cruzers today and I am extremely pleased with the result. I would not say it has made the exhaust quiet by any stretch of the imagination but it has taken out some of the volume and more importantly the bark, which in my opinion was above and beyond what I would consider to be acceptable to Joe public. The noise level was also starting to p*ss me off when riding at high-speed. On tick over the bike is a lot quieter, possibly somewhere in the region of 25% reduction in volume throughout the rev range. I did follow Alfie's advice and fit the Hardkromes without removing the Cruzer's baffle as Alfie had an issue with the original packaging becoming loose. I didn't drill holes tho' for the self tapping screws, I just put pressure on with my drill and used a couple of smaller screws and they made the hole quite easily before installing the self tappers. To be honest I snapped my last correctly sized drill bit on the first hole, so made do with that approach. All in all I am very pleased that I bought these baffles as I love the look of the Cruzers but they were just a little to noisy for me. I like a Cruiser to have a nice throaty sound with a descent level of volume and a bit of bark and with these baffles installed, that's exactly what I have!
I did promise a video of before and after but will have to apologies as I bolloxed it up but will do it at a later date.
Last edited by Mr Intruder on Sat Jan 28, 2012 10:20 pm; edited 2 times in total | |
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Sat Oct 08, 2011 4:19 pm | |
| Cool, glad your happy with the result Always handy when you can get tips off other members before doing any install, sounds like Alfies advice sent you in the right direction. | |
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Sat Oct 08, 2011 4:49 pm | |
| - captain crash wrote:
- Cool, glad your happy with the result
Always handy when you can get tips off other members before doing any install, sounds like Alfies advice sent you in the right direction. Spot on, Alfie saved me a bit of hastle and I have just got back from a ride and I love the result | |
|  | | pledge Valued Member
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Sat Oct 08, 2011 5:52 pm | |
| I'm pleased your're happy with the out come. | |
|  | | alfie92 Very Valued VIP Member
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Sat Oct 08, 2011 7:00 pm | |
| Glad to see you are happy with the baffles,like you I prefer the cruiser pipes,but they do need to be a little quieter.Just a note to anyone wishing to take the baffles out of the V&H cruiser pipes carefully mark the position of the baffle before you remove it,especially were the grub screw goes for you only have a liitle hole to put the screw back in,and believe me it is a pain if not marked up right before you start. | |
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Sun Oct 09, 2011 3:43 pm | |
| Alfie, as promised a bit of info on the Baffles The pepper pot section is drilled with 2mm holes evenly spaced with non holed area The pepper pot section also has a wavey sheet of steel running along that section only, which basically splits that section in to two It would not be advisable under any circumstance to fit the HardKrome Quiet Baffle to a removed stock baffle due to the exact and extremelly tight fit back plate 3" accross Baffle tube width 1.50" tube 6.75" from end to end pepper pot section of tube 5.25" long solid, non pepper pot section of tube 1.50" long  | |
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Sun Oct 09, 2011 5:43 pm | |
| Hmmm with those specs explained, that would make the baffles very easy for someone with metal skills to copy | |
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Sun Oct 09, 2011 11:23 pm | |
| Sound cheers Dave well explained,easy to understand.The solid part can be made from any stainless steel/mild steel, what comes to mind is the bar holders that you can purchase from B&Q and the like for hanging a clothes rack in your wardrobe,bearing in mind that they would have to have a 1.50" hole in.The pepper pot area,that can be made from small strong mesh/grateing made round to fit,holed or diamond patern would suffice approx 2mm thick.This is only my idea of making these,if anybody wishes to take on board what I have wrote please feel free to do so with no reprecusions to myself.Once again Dave thanks for taking the time to send me the details,I love this forum very imformative and helpful. | |
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Mon Oct 10, 2011 7:53 pm | |
| Flippin eck Alfie, I just re read your post and I love the way your brain works by simply using things that are easily accessable in the local shops. Between you and Dave your a right couple of pirates  | |
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Mon Oct 10, 2011 7:57 pm | |
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Tue Oct 18, 2011 1:00 pm | |
| [img]  [/img] [img]  [/img] Hi Dave here is my version of quiet baffles made from scrap,the welding has been tieded up,the good thing is they are hidden,also they do work.Cheers for you input Dave helped a lot.The grill was an old diesel cage,two 2.5" washers and a piece of vacuum cleaner pipe. | |
 | Subject: Alfie's Aftermarket's Tue Oct 18, 2011 6:48 pm | |
|  Bloody Hell what a good job First of all we had the Bluesman mod & now we got Alfies Aftermarket's  Q, Are the washers actualy wide enough to drill for self tappers to go in to the stock baffles? | |
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Tue Oct 18, 2011 7:17 pm | |
| Fantastic, Alfie's Aftermarkets. That's got a good ring to it, well done Alfie  | |
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Tue Oct 18, 2011 10:42 pm | |
| Hi Dave what I done was drilled the vacuum pipe whilst in the main baffle then placed a nylock 10mm nut to a bolt passing through both.This will not shake loose or melt as the heat is not that severe.What it means is that I have to remove the main baffle to do any mods,but I have made a template to be able to easily connect the baffle back into position when needed. | |
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Wed Oct 19, 2011 7:42 am | |
| Very clever and tidy way to do it | |
 | |  | | stone Member
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Wed Oct 26, 2011 5:35 pm | |
| Where did you puchase you HardKrome Quiet Baffles Mr I | |
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Wed Oct 26, 2011 6:05 pm | |
| - stone wrote:
- Where did you puchase you HardKrome Quiet Baffles Mr I
I'd be interested to know also, I'm sure Mr I did say where he got them from but I can't find the post now. | |
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Wed Oct 26, 2011 7:13 pm | |
| SmartPartz Site LINK It would seem they are not available in the UK I did get hit for £17 before collection at the Post Office
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Wed Oct 26, 2011 7:19 pm | |
| Thanks Mr I.  | |
|  | | stone Member
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Wed Oct 26, 2011 7:26 pm | |
| Cheers Mr I.
£17 sounds v steep for import duties. Works out at about £80 for a couple of bits of pipe!!!
Might try making some | |
|  | | stone Member
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Sat Oct 29, 2011 7:49 am | |
| Decided to order some Hard Kore baffles. See if I get hit with £17 at post office. | |
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Sat Oct 29, 2011 7:46 pm | |
| It's robbery for sure but with most stuff it still works out cheaper than buying the same product in this country (thats if you can get stuff here, which often you can't) | |
|  | | stone Member
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Wed Nov 02, 2011 4:48 pm | |
| Didnt get hit for £17 import duties. Must be my luck day!! | |
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 * Wed Nov 02, 2011 5:37 pm | |
| That's exactly what it was, importing is a lottery. Lucky you  | |
|  | | Sponsored content
 | Subject: Re: * HardKrome Quite Baffles For V&H Cruzers C800 *  | |
Similar topics |  |
Latest topics | » Gudday from the land where blood rushes to your head (upside down)
by beachartist Yesterday at 1:10 am
by Ray944 Sun Jul 09, 2023 5:41 am
