 No drive
2 posters
Phil
No drive Empty
PostSubject: No drive   No drive Icon_minitimeMon Sep 07, 2020 10:54 am
Hi guys im new to the site & thanks for having me. I recently got a 92 model vs 800 was riding it home from buying it & it lost all drive i tried roadside adjusting the clutch at the handiebars. Was not slipping prior to losing drive no bangs or gringing sounds. Sorta got me beat. Any help would be appreciated
wanad83
No drive Empty
PostSubject: Re: No drive   No drive Icon_minitimeThu Sep 10, 2020 12:25 am
Make sure the pressure return hole is clear in the bottom of the clutch master cylinder. If clogged it will cause pressure to build up and make the clutch slip. A good indication of this is when the longer you ride, the worse the slipping gets. You can bleed the pressure off the clutch hose, then try to ride the bike. If is starts working, the clutch master cylinder is plugged up and the clutch will start to disengage again soon.
No drive
» Rear drive 'spider' cush drive thingy
» anybody ever thought to switch to belt-drive primary-drive?!
» Final drive
» VS1400 Drive
» shaft drive
No drive Icon_minitimeby KeithW Mon Oct 02, 2023 5:13 pm
No drive Icon_minitimeby beachartist Sun Sep 24, 2023 1:10 am
No drive Icon_minitimeby ian7be Mon Sep 18, 2023 7:47 am
No drive Icon_minitimeby Reggyreg Sat Sep 16, 2023 8:41 pm
No drive Icon_minitimeby webrider Thu Sep 14, 2023 1:34 pm
No drive Icon_minitimeby Nat Mon Sep 11, 2023 9:56 pm
No drive Icon_minitimeby greatwave Thu Sep 07, 2023 1:38 am
No drive Icon_minitimeby Groovy Dinner Wed Sep 06, 2023 6:44 pm
No drive Icon_minitimeby Badger Mon Sep 04, 2023 11:42 am
No drive Icon_minitimeby Badger Thu Aug 24, 2023 11:08 am
No drive Icon_minitimeby flying1 Thu Aug 24, 2023 10:38 am
No drive Icon_minitimeby Fergal Tue Aug 08, 2023 6:18 pm
No drive Icon_minitimeby Fergal Tue Aug 08, 2023 6:09 pm
No drive Icon_minitimeby Badger Wed Jul 26, 2023 10:31 am
No drive Icon_minitimeby Badger Mon Jul 17, 2023 9:05 am
No drive Icon_minitimeby Fargo02 Mon Jul 17, 2023 1:28 am
No drive Icon_minitimeby Slickrickk Mon Jul 17, 2023 12:36 am
No drive Icon_minitimeby Damion Jones Sun Jul 16, 2023 11:22 pm
No drive Icon_minitimeby BEEMERED Sun Jul 16, 2023 1:41 pm
No drive Icon_minitimeby uskydoo Sun Jul 16, 2023 10:45 am
