 VX reg/rec location
3 posters
Billy Bananahead
VX reg/rec location Empty
PostSubject: VX reg/rec location   VX reg/rec location Icon_minitimeSat Mar 20, 2021 2:58 pm
Doing a service on the swingarm bearings and shaft drive and came across the location of the reg/rec unit.
Moved it out of the way from behind the engine /swingarm area and relocated it between the fusebox and rear brake master cylinder. Got to be a better place.
BONE1
PostSubject: Re: VX reg/rec location   VX reg/rec location Icon_minitimeSat Mar 20, 2021 8:45 pm
It is a bit random where they stuck it I only found where mine was the other day as had a wiring issue. Can't quite picture where you have moved it to but I would make sure it's still getting air to it as these can get hot an fail as a result. I relocated my gsxr reg/rec and it melted some foam padding in that area. just something to bare in mind.
Billy Bananahead
PostSubject: Re: VX reg/rec location   VX reg/rec location Icon_minitimeSun Mar 21, 2021 7:26 am
Thanks for the tip. I'll look into it.
Damion Jones
PostSubject: Re: VX reg/rec location   VX reg/rec location Icon_minitimeWed Dec 29, 2021 8:16 pm
Just adding one small note to an old post.
I just came on to look to ask if anyone knows where the hell it is located at, and I found this post.
Mine is a 1990 heavily customized bobber with no backend and forward controls and the headlights are useless as they can possibly be. I have put twin lights on and itys not helpedat all and so I got an LED headlamp and that too is not as good as it should be. The radiator fan spins up and when I put the lights on, the fan is audibly quieter and the whole electric system is poor at best.
So I went and bought myself a new Reg/Rec only to then realise that I cannot for the life of me find the original to replace it????
So its behind the engine under the shaft drive swing arm sort of area?
Im 95% sure that I looked around there, but hey ho.
My harley sportster had its one right at the front at the bottom... Well in teh dirt and muck, but at least in the cool wind I suppose?
VX reg/rec location
» Location of pannier brackets
» 2008 Suzuki intruder 800, location of wires for fuel injectors from ec
VX reg/rec location Icon_minitimeby tkennar Yesterday at 4:47 pm
VX reg/rec location Icon_minitimeby JimboJ Sun Mar 12, 2023 1:14 pm
VX reg/rec location Icon_minitimeby beachartist Sun Mar 12, 2023 12:50 am
VX reg/rec location Icon_minitimeby Kev Sat Mar 11, 2023 9:02 am
VX reg/rec location Icon_minitimeby adilmon Fri Mar 10, 2023 2:08 pm
VX reg/rec location Icon_minitimeby Born to be mild Thu Mar 02, 2023 11:10 am
VX reg/rec location Icon_minitimeby flying1 Wed Mar 01, 2023 9:43 am
VX reg/rec location Icon_minitimeby Damion Jones Sun Feb 26, 2023 8:00 pm
VX reg/rec location Icon_minitimeby flying1 Sat Feb 25, 2023 10:08 pm
VX reg/rec location Icon_minitimeby flying1 Sat Feb 25, 2023 4:52 pm
VX reg/rec location Icon_minitimeby Damion Jones Fri Feb 24, 2023 11:59 pm
VX reg/rec location Icon_minitimeby Big Rab Thu Feb 23, 2023 6:18 pm
VX reg/rec location Icon_minitimeby ardie Tue Feb 14, 2023 7:14 pm
VX reg/rec location Icon_minitimeby Badger Sun Feb 12, 2023 4:31 pm
VX reg/rec location Icon_minitimeby Big Rab Mon Feb 06, 2023 5:25 pm
VX reg/rec location Icon_minitimeby Bobby Thu Feb 02, 2023 2:41 pm
VX reg/rec location Icon_minitimeby Ray Noble Wed Jan 18, 2023 11:19 am
VX reg/rec location Icon_minitimeby gioniko73 Tue Jan 17, 2023 12:09 am
VX reg/rec location Icon_minitimeby james mclaughlin Sat Jan 14, 2023 4:01 pm
VX reg/rec location Icon_minitimeby Badger Thu Jan 12, 2023 3:17 pm
