| | VX800 clutch cable adjustment | |
Bloke Prospect
 | Subject: VX800 clutch cable adjustment Tue May 17, 2022 2:22 pm | |
| Hi I don't seem to be able to get a consistent clutch cable adjustment at the lever on the VX. I follow the manual when i adjust the clutch.....it just seems a bit weird that you have to end up with the correct adjustment at the lever when it's cable adjustment is screwed all the way in .....by adjusting the cable at the engine casing. It seems that to get the right adjustment at the lever the clutch is slightly operated due to the adjuster at the engine casing being wound out so far. What I noticed is the the "worm drive" adjustment is worn.....it has side to side play when you operate the clutch. If I get a good adjustment of the cable...the cable play seems to increase a bit each time I use the clutch. The first few gears "clunk" a bit when engaging and the clutch tends to engage near the end of the lever travel. I've only ridden the bike a few times so I'm still getting used to it. Cheers | |
|  | | oldmick Member
 | Subject: Re: VX800 clutch cable adjustment Mon May 23, 2022 6:00 pm | |
| Hi, I may be misunderstanding but if you have play at the lever, how can the clutch be 'slightly operated', (by 'slightly operated' I assume you mean slightly disengaged). Regards, Mick | |
|  | | oldmick Member
 | Subject: Re: VX800 clutch cable adjustment Mon May 23, 2022 7:02 pm | |
| Hi Again, I'm guessing you're looking at the owner's manual. There is a more detailed procedure in the workshop manual which might help. I can copy it out for you if you don't have one. Regards, Mick | |
|  | | Bloke Prospect
 | Subject: Re: VX800 clutch cable adjustment Tue May 24, 2022 12:13 pm | |
| Thanks oldmick...I just got a copy of the manual and readjusted the cable and now I have a good working clutch. Cheers | |
|  | | Sponsored content
 | Subject: Re: VX800 clutch cable adjustment  | |
Similar topics |  |
Latest topics | » Idiot lights
by Buttsy13 Thu Jun 30, 2022 4:48 pm
by Buttsy13 Thu Jun 30, 2022 2:48 pm
» Hello, help with broken Lamda
by Badger Wed Jun 29, 2022 11:11 am
» Nice to be here
by Cannon Sun Jun 26, 2022 10:29 pm
» VX800 Help please, where is the fan connection located.
by rupert Sat Jun 25, 2022 10:10 am
» hi all just to introduce myself
by Badger Fri Jun 24, 2022 3:03 pm
» Sachs Roadster 800 porn
by Badger Fri Jun 24, 2022 1:48 pm
» VX800. Radiator and fan connections.
by rupert Fri Jun 24, 2022 1:21 pm
» In search of wide tire kit to complete my dream build.
by InfiniteReality Sun Jun 19, 2022 6:59 am
» New
by B1gTw1ZTed Fri Jun 17, 2022 11:33 pm
» Ic igniter wanted vs800
by Salste Sun Jun 12, 2022 10:33 pm
» Ic igniter needed
by Salste Sun Jun 12, 2022 10:23 pm
» Introduce myself salste
by Salste Sun Jun 12, 2022 9:22 pm
» Hello from Australia
by Wizard064 Sat Jun 11, 2022 2:58 am
» Hi there
by ros Thu Jun 09, 2022 8:20 am
» Hello From Sunny *haha* Manchester UK
by Tommydoh Mon Jun 06, 2022 11:03 pm
» Looking for handlebar replacement VZ800 Marauder
by mdegroat Fri Jun 03, 2022 4:12 am
» Tow bar
by bigmal Wed Jun 01, 2022 8:06 am
» Electrics
by Daleboy Sat May 28, 2022 6:24 am
» VL 800
by Neurofire Fri May 27, 2022 2:46 am
