 Help! Water pump removal question 1997 VS800
LNB
Help! Water pump removal question 1997 VS800 Empty
PostSubject: Help! Water pump removal question 1997 VS800   Help! Water pump removal question 1997 VS800 Icon_minitimeWed Jul 06, 2022 3:21 pm
VS800 1997
I have a leaky oil seal in my water pump and I am attempting to rebuild the pump's seals. Unfortunately, I cannot seem to line up the three screws to the plate behind the impeller. I have one screw lined up with the hole in the impeller but have no idea how to get the other two lined up. There is three holes in the impeller and they have to line up with the back plate to remove the screws in order to put the water pump guts.
DOES ANYONE OUT THERE KNOW OF AN EASY WAY TO LINE UP THE HOLES IN THE IMPELLER WITH THE SCREWS?
LNB
PostSubject: Re: Help! Water pump removal question 1997 VS800   Help! Water pump removal question 1997 VS800 Icon_minitimeWed Jul 06, 2022 8:38 pm
Ok, so I wasn't thinking. I got my neighbor to come over and move the bike forward and backward in 5th gear while I lined up the impeller holes with the three screw heads. Only one screw came loose, so the other two will have to be drilled out. Thought this water pump seal rebuild was going to be fast and easy. No so.
LNB
PostSubject: Re: Help! Water pump removal question 1997 VS800   Help! Water pump removal question 1997 VS800 Icon_minitimeTue Jul 19, 2022 7:49 pm
Replaced all the water pump seals and put it back on the bike. Idled it for a while so I could refill the coolant but I noticed that the fan never came on. Of course, I haven't put it on the street yet, so maybe it has to really heat up. It is hot (90's) and humid today, and the coolant did get really hot even bubbling over without the cap on it. I just wanted to fill the air pocket from what I lost when I removed the water pump. I will do an oil filter and oil change tomorrow and then maybe put it on the road to see if the water level goes down or not. So far, no leaks from the water pump, so I must have done it right. I'll check tomorrow morning to see if that little leak reoccurs.
» water pump extraction vl 700
» Water Temperature Sender Unit Removal
» Valerie E's Baby . . . . . 1997 Suzuki VS800
» Installing coolant/water temperature gauge . . . . . . (Now Done)
» Air cleaner removal question
Suzuki 800 Intruder Club & Forum :: The Garage :: Cooling system-
» My BoulivardC50 2004 is missing when it gets hot.
Help! Water pump removal question 1997 VS800 Icon_minitimeby Badger Wed May 24, 2023 11:08 pm
» Greetings from Canada
Help! Water pump removal question 1997 VS800 Icon_minitimeby CanuckVZ800 Sun May 21, 2023 7:15 pm
» Just saying a BIG Hi from Dublin Ireland
Help! Water pump removal question 1997 VS800 Icon_minitimeby Aikido789 Sun May 21, 2023 10:48 am
» my new bike
Help! Water pump removal question 1997 VS800 Icon_minitimeby Kevski Thu May 18, 2023 9:13 pm
» Horn
Help! Water pump removal question 1997 VS800 Icon_minitimeby flying1 Thu May 18, 2023 2:25 pm
» Hello from Lakeland, FL USA
Help! Water pump removal question 1997 VS800 Icon_minitimeby Renegade Sat May 13, 2023 8:05 pm
» Hello!!
Help! Water pump removal question 1997 VS800 Icon_minitimeby alvinlee01 Tue May 09, 2023 11:29 am
Help! Water pump removal question 1997 VS800 Icon_minitimeby JimboJ Sun May 07, 2023 11:29 pm
» E10 petrol
Help! Water pump removal question 1997 VS800 Icon_minitimeby Two-Bears Sat May 06, 2023 12:09 am
Help! Water pump removal question 1997 VS800 Icon_minitimeby Two-Bears Fri May 05, 2023 11:58 pm
» Starting problems/Relay?
Help! Water pump removal question 1997 VS800 Icon_minitimeby Badger Fri Apr 21, 2023 8:12 pm
» New Member (I hope!)
Help! Water pump removal question 1997 VS800 Icon_minitimeby Badger Fri Apr 21, 2023 8:08 pm
» Oil pressure gauge & test port
Help! Water pump removal question 1997 VS800 Icon_minitimeby Stevie Mac Wed Apr 19, 2023 11:50 am
» Vs 800 gl
Help! Water pump removal question 1997 VS800 Icon_minitimeby Apache Mon Apr 17, 2023 1:46 am
Help! Water pump removal question 1997 VS800 Icon_minitimeby skraecken Wed Apr 12, 2023 5:24 pm
» Valve clearance check
Help! Water pump removal question 1997 VS800 Icon_minitimeby BikerRon# Mon Apr 10, 2023 11:33 pm
Help! Water pump removal question 1997 VS800 Icon_minitimeby tkennar Mon Mar 20, 2023 4:47 pm
Help! Water pump removal question 1997 VS800 Icon_minitimeby JimboJ Sun Mar 12, 2023 1:14 pm
Help! Water pump removal question 1997 VS800 Icon_minitimeby Kev Sat Mar 11, 2023 9:02 am
Help! Water pump removal question 1997 VS800 Icon_minitimeby adilmon Fri Mar 10, 2023 2:08 pm
