| | Sparkplugs problem | |
LuisGuillermo Prospect
| Subject: Sparkplugs problem Fri Jul 11, 2014 10:27 pm | |
| friends! Could you give a hand? I have a M50 Vz800 2006, I have a serious problems with spark plugs. Every day I have to change both spark plugs, completely dirty! My bike worked good with DPR8EA9, but not now, I tried with DPR7EA9, DPR6EA9, the same problem. I changed the ignition coil assy, the control unit F1. Until now.. the same problem! I have no idea what happened! Thanks for your help! | |
| Subject: Re: Sparkplugs problem Fri Jul 11, 2014 11:24 pm | |
| Hi Luis, dirty air filter? Valve clearance/seals? Piston rings? Any more info on the bike?,eg, mileage, state of tune and service etc, does it run then cut out due to fouling? not start at all? the more info the better, You've tried hotter and colder running plugs and changed the ignition and FI, Is there a good spark? did you change the injectors or just the FI unit?, FI unit, as in processor or ECU? Any info helps thanks. | |
| | | TwinDad Member
| Subject: Re: Sparkplugs problem Fri Jul 11, 2014 11:34 pm | |
| Sounds like an injector issue, over fuelling. That goes back to FI system, get brain into gear and have a deep think! | |
| | | Two-Bears * VZ Guru *
| Subject: Re: Sparkplugs problem Sat Jul 12, 2014 6:34 am | |
| Hello Luis, I agree with George here, fuelling fault and Sim dirty air filter,,, Do you have any fault codes flashing F1 light on the clock ?. | |
| Subject: Re: Sparkplugs problem Mon Jul 14, 2014 3:22 pm | |
| Hello friends! thanks for you help!! No codes at all, I clean the filter K/n. my bike has 54 000 milles aprox. I didnt chance the inyectors, I just cleaned two times, valves adjusted. I don´t change the Pistons rings until now. At minimun the bike works ok. Thanks a lot ! Sim, George and John! I appreciate your help! | |
| Subject: Re: Sparkplugs problem Wed Jul 16, 2014 6:41 pm | |
| Hello again friends! Yesterday night I tested the compression pressure; according to the manual it is very low…
Front Cylinder: 50-135 PSI
Rear Cylinder: 50-75 PSI... | |
| Subject: Re: Sparkplugs problem | |
Latest topics | » just saying hello to this site by sgtruth60@gmail.com Yesterday at 8:04 pm
» Newbie by M800chimp Yesterday at 11:28 am
